Do you prefer a bunk or roller trailer? >
Old 12-06-2009 | 04:02 PM
Default Do you prefer a bunk or roller trailer?
I was wondering what type of trailer you guys prefer and why?
twistedvelocity is offline
Old 12-06-2009 | 06:54 PM
For a bigger,heavier boat I think a bunk will support the boat better. I think rollers will eventually warp or put dimples in the hull. also with rollers you better be ready B/C they work to good at the ramp.....see a couple of boats slide right off the trailer when backing down the ramp.
tcuda499 is offline
Old 12-07-2009 | 09:02 AM
tblrklakemo's Avatar
SeaRay Sundancer
Bunks...more support. Just back in far enough next to a courtesy dock and you can float the boat on and off the bunks.
tblrklakemo is offline
Old 12-07-2009 | 09:58 AM
Bunk Period.
laszlo01 is offline
Old 12-07-2009 | 11:10 AM
Brad Zastrow's Avatar
Roller trailers will warp the hull bottom over time. None of the high end trailer manufacturers use rollers.
Brad Zastrow is offline
Old 12-07-2009 | 02:29 PM
Bunk, too many problems with rollers, also I have seen some boats roll off rollers accidentially
TampaBeach is offline
Old 12-07-2009 | 04:38 PM
seafordguy's Avatar
This is offshore boating - bunks.
Rollers are for Boston Whalers....
IN all seriousness I would not want much weight on rollers. With the bunks it is easy to get the trailer in just the right distance so that you can bump the boat up on the bunks, and it will help steady it with the resistance.
seafordguy is offline
Old 12-07-2009 | 05:29 PM
socalstone's Avatar
Bunks only. Wouldn't consider rollers for anything.
socalstone is offline
Old 12-07-2009 | 09:18 PM
Bunks on the average will give you 5 times morre support against the hull and it is spaced more evenly. The only drawback is if you are on a shallow ramp there may not be enough water to submerse the boat and trailer deep enough into the water to float it off.Other than that bunks are the way to go. Also any boat over 26' should have target bunks on the front for additional keel support and it will also help centering the boat.
If anyone has other questions I have been selling repairing and making trailers for 30 years. I am here to help
Neil
snogiyogi is offline
Old 12-09-2009 | 11:02 PM
I have a 23 1/2 foot boat right now and it is a roller trailer and i need to repair the hull. SO I am thinking it might be a good idea to take the rollers out and make bunks
