New Intake
Old 12-07-2009 | 08:19 AM
Default New Intake
I am thinking of replacing the intake on my 540. Current intake is an old Professional Products model called a “Hurricane”..
I would like to put a dominator on the motor.. Anyone have an opinion on the “best” intake?
Motor is a 540 decent but Mild cam. 9:1 comp.. Nothing major earth shattering done to engine. Heads are Canfield 310 with some work done..
I am leaning toward a Brodex or the marine Merlin..
Thoughts?
Also.. When installing, do I need to trim the gasket around the ports on the heads? Intake? Should I pop new lifters into the motor? These lifters have about 150/hrs on them.. About 4 seasons on the motor now..
JohnSchiavarelli is offline
Old 12-08-2009 | 07:50 AM
Anyone?? Best intake for a NA 540??????
Old 12-08-2009 | 10:40 AM
CB-BLR's Avatar
Chris
I did some testing a couple of years back on both manifolds and carbs for my N/A 540 with AFR 315 heads.
Best dyno numbers were made with a port matched Edelbrock Victor manifold, a 1" HVH supersucker spacer, and a 1050 Dominator carb.
Chris
CB-BLR is offline
