Question about Eddie Marine Exhaust
I am in the process of repowering my Baja 250 ES. I am going from a 468 bbc to a 572 bb. I currently have Eddie Marine Thunder Exhaust. I was told today that those exhaust would not work with that many cubic inches due to water reversion. Thanks in advance for any input. Sidney
We ran Eddie Marines on a 540 I built with 758 dynoed HP and never had an issue. The reversion issue is not so much the exhaust manifold, but the cam that you might be running. If reversion is a concern...get the long risers and you should be fine. I ran the short risers like the ones that you would use to hook up the silent choice or Corsa thingy.
SidneyW , listen to what Eddie says. We have a ZZ 572 that we put the EMI Thunder exhaust system on. Believe it or not we didn't loose much power going from the dry Stellings ,but we started having reversion at idle.
We asked Eddie to make taller risers for us , and that cured the problem!
Stellings were way too loud for my friend's marina ,and also kept cracking at the exhaust flange on the inside tube ,so had to go.
Stelling setup
Eddie setup
Interir db testing without the doghouse
http://www.youtube.com/watch?v=6L-st0izosU
Still has a nice runble with the mufflers
http://www.youtube.com/watch?v=QtMEm...eature=related
Stelling setup
Eddie setup
http://www.eddiemarine.com/store/car...l&p=13075&c=63
The link is the 540 motor that is making 758 HP and it is the same motor that had the Eddie marine exhaust manifolds on with the SHORT risers running a Crane #139741 hydraulic roller cam for alittle over 11 months. The motor has CMI headers on it now...$4500.00...what a waste of money for the CMI's. Only got a 2 mph increase by going to teh CMI headers. Wont EVER make that screwup again.
http://www.youtube.com/watch?v=a7q182DGDm0
The 572 in the pics...is that a crate motor from Jegs or Summit Racing...looks exactly like what they offer, because if it is, then its a car motor and no wonder there is reversion. The cam causes reversion...NOT the size of the motor.
The cam was changed when the dry exhaust was removed!
Thanks so much for your info. I will check into higher risers. This thing is killing me financially!I may just go back with my 468 and sell the 572. That is a nice setup you have!What kind of boat is that?
