Oil sandwich plate ???
I have a gen 6 502 and would like to remove the oil housing that is mounted on the block and use a housing that I can attach a oil filter to and run to a cooler. Does anyone know of one make and model number.
check out summit or ebay. there are several good ones out there and not that expensive either. i was going to go the same route also. keeps things simple as long as you have the room as i did.
