Installing trim tabs
Old 12-27-2009 | 09:54 AM
Default Installing trim tabs
I just bought a set of Eddie marine trim tabs and am getiing reading to install them. I am going to make a template out of 1" alum so the mounting holes are straight. I am told to use silicone for where the mounting holes and trim lines come in. Anyone recommend a brand or type to use? Also where the indicator cables mount thru the transom. I've seen them mounted on other boats up as high as the thru hull exhaust. I personally dont like the to see the cables and wanted to mount them as low to the water line as possible. And ideas or experience?
capt2130 is offline
Old 12-27-2009 | 10:03 AM
You mean that Eck girl that works at Gifford Lumber wouldnt know?
JohnnyMarshall is offline
Old 12-27-2009 | 10:10 AM
Audiofn's Avatar
Charter Member #232
I would use 3m 4200 to seal them up. My cables are underwater on the K-planes and they don't leak at all. Not sure who would make a similiar fitting? Maybe Lavorsi?
Jon
Put your best foot forward!
Audiofn is offline
Old 12-27-2009 | 10:37 AM
Well I did ask Mandy at Giffords and she didnt know.
capt2130 is offline
Old 12-27-2009 | 10:31 PM
glassdave's Avatar
Neno the mind boggler
also keep in mind that you dont mount tabs flush with the edge of the running surface. Mine are an inch up, Donzi factory mounted 280 K planes. I have seen them as close as a quarter inch or so.
08 OPA High Points Champion
glassdave is offline
Old 12-27-2009 | 10:52 PM
Jon
+1 on the 4200
Ditto. 1/2- 1 inch above the bottom.
Griff is offline
Old 12-27-2009 | 11:36 PM
Velocity Vector's Avatar
Crazy Energy
Originally Posted by Griff
+1 on the 4200
Do it once do it right read above
Velocity Vector is offline
Old 12-28-2009 | 05:29 AM
Thanks for your input gentleman.
capt2130 is offline
Old 12-28-2009 | 12:45 PM
Im lookin for 280 Merc tabs with pump and everything for assembly if anyone knows of a set out there used and in good condition please let me know.
Old 12-28-2009 | 07:36 PM
I remember seeing a thread about two years ago of an install of some K-Planes. The author of the thread was using some type of guide while drilling to ensure the holes where exactly 90 degrees. It had pictures and everything, been looking for two weeks and can't find the thread.
Anyone know the tool that was used or know the thread I'm referring to?
thanx
bert4332 is offline
