272/302 windscreen... where to find one?
I'd ask Mike see if he'll trade you for the one off his boat. If not I wish you good luck finding one Scott. I looked for 2yrs and then lucked out and found 2. Spartech is now defunct unless someone picks up they're line so I couldn't even let you use the one I have in a crate for a mold. I'll keep my eyes open.
j/p bro!I will check into it!
Yeah I shot Mike an email, we will see what he says....
Custom Interiors & More
XT
The fit on the front section would be a little loose, or large to fit tight, but you could fill the void on the inside with a foam tape, or something? The side wings will be around 8" short, and the bottom contour will be too flat. (not enough belly) The side wings are made with just (flat) plex. so you could make wings to fit if you can get matching material?
XT
XT
