Dose anyone need A Fuel Tank Sending Unit with A Return Line already installed ? >
Old 12-29-2009 | 12:44 AM
Default Dose anyone need A Fuel Tank Sending Unit with A Return Line already installed ?
Attention Engine Builders and Boat Riggers, Here is A Fuel Tank Sending Unit with A Return Line already installed to the base of the sending unit. This should help make some of the after market EFI engines a little more easier and safer to set up for some of performance shops that need to run a return line back to the fuel tank. I thought this was interesting and Just wanted to share what I found today with you all.
http://www.amazon.com/Moeller-Marine.../dp/B000MTI15U
Boat Tech is offline
