Skater 388 vs 40
Old 12-30-2009 | 06:38 AM
Default Skater 388 vs 40
That video of Gatorone in Pure Platinum really gets the adrenaline pumping. Last winter I stopped by the Skater factory to see what was going on and have not stopped thinking about the 40 Skater. Is there a significant difference between these 2 hulls and their rough water capabilities. Is the 388 an extended version of the 368 or an entirely different hull.
Enough 4 Play is offline
Old 12-30-2009 | 12:31 PM
JIMKID Motorsports's Avatar
388 tottaly different hull same with the 40 both great hulls the 368 is the 36 with 8 inches added to the tunnel width but also a different mold not cut up
JIMKID Motorsports is offline
Old 12-30-2009 | 01:21 PM
WARPARTY36's Avatar
Drive to arrive alive!!!
Here are a couple of shots of Pure Platinum(388) next to No Plans(40) for comparison.
Attached Thumbnails Skater 388 vs 40-skaters.jpg   Skater 388 vs 40-skaterfront.jpg
WARPARTY36 is offline
Old 12-30-2009 | 02:48 PM
Now your on the right track to go FAST!!...
cats are great fun...
customryder is offline
Old 12-30-2009 | 04:19 PM
Coolerman's Avatar
PF Marine
aren't there 2 diff 40 hulls? The 40ss (shortened 46), and then the original 40 with the flat deck or classic deck?
Coolerman is offline
Old 12-30-2009 | 05:49 PM
HotPursuit's Avatar
That is correct But the 40SS is not as wide and a different mold. 11'6 beam
40 SS best in rough water less speed per HP- weight ratio
40 Classic less rough than a SS but depending on the lay up close in speed HP-weight ratio 10'11 beam
38.8 Faster with same HP_weight ratio but less rough handling..also turns the courners faster. 11' beam
HotPursuit is offline
Old 12-30-2009 | 05:59 PM
KNOT-RIGHT's Avatar
That would make the 40ss 12 feet wide?
KNOT-RIGHT is offline
Old 12-30-2009 | 06:46 PM
Strip Poker 388's Avatar
Rob
388 faster.Look at all the 388 race boats out there.
Strip Poker 388 is offline
Old 12-30-2009 | 08:00 PM
No i believe it is 11-6
Detail Toyz is offline
Old 12-30-2009 | 11:59 PM
11'10''
skater40 is offline
