Shift bracket wire question. >
Old 12-31-2009 | 10:28 PM
Default Shift bracket wire question.
I'm still working on wires in engine compartment. Found what most of them are for. Just these 2 sets of wires left. Large orange and black,and orange red and brown zip tied together. Might they be the shift bracket wires?
89 Baja 250 is offline
Old 01-01-2010 | 08:54 AM
On my 265 the large ORG and BLK go to the hatch actuator. And the RED,ORG,and BRN go to the Mercathode.
Everything else looks very similar to mine.
ittledoo is offline
Old 01-01-2010 | 09:05 AM
hoozeyurdaddy's Avatar
red,orange.brown are mercathode. orange and black may be hatch or power for K planes, could be some kind of setup for charging sys. try to trace them to where they go.
hoozeyurdaddy is offline
Old 01-01-2010 | 10:13 AM
Default Mercathode
Thanks guys. Is the Mercathode needed? I am running in fresh water only.Is it an expensive system?
Old 01-01-2010 | 10:15 AM
More guys on here will know the details, but the I've been told that the Mercathode is definitely needed!
ittledoo is offline
Old 01-01-2010 | 03:59 PM
Is the boat left in the water all the time or trailered? If it's always trailered out I wouldn't worry about it.
picklenjim is offline
Old 01-01-2010 | 04:05 PM
It's a system that protects your drive against corrosion.It consist of 2 "pucks" mounted on the transom,one on each side of the drive which are wired to a control box. They create a field that protects the drive. If it says Mercury on it you know it's expensive!! If your boat is not in the water 24/7 I wouldn't worry about it.
Old 01-01-2010 | 04:33 PM
While your in there get rid of those wire connectors and use heat shrink connectors. Those will corrode and cause problems.
tms1155 is offline
Old 01-01-2010 | 05:07 PM
I don't keep it in the water.On trailer. Thanks. I will remove the but connectors.
Old 01-01-2010 | 06:12 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Go to Autozone and buy a qt of fiberglass resin and seal the holes that go thru the stringers for draining if they are just drilled with no protection. From looking at the pic, it appears to be raw exposed wood.
US1 Fountain is offline
