35 Motion with triple outboards
I'm rigging a 35 Motion with triple outboards on CMC jackplates, where should the outer outboards be rigged, how close to the tunnel? the engine height is 25" for the outer engines and 20" for the center engine? also some help as to engine height both for the outer engines and the center engine would be appreciated.
Crazy Energy
I really don't see where trips will help you much if any maybe just use more fuel. The extra weight, fuel cost, covering the tunnel less air gets thru plus the cost factor for the engine and rigging VS any MPH gain, really makes no sence to me. Just my two cents.
I had one I will try to look pictures to post. mine was the old patriot boat. 108 mph 100 mph all day long no headaches. just lots of fuel and oil.
BY THE WAY THE THIRD MOTOR IS DEFFENTLELY A MUST WITHOUT IT IT ONT RUN
