Motion 35 trip outboards
Old 01-01-2010 | 04:40 PM
Default Motion 35 trip outboards
I'm rigging a 35 Motion with triple outboards on CMC jackplates, where should the outer outboards be rigged, how close to the tunnel? the engine height is 25" for the outer engines and 20" for the center engine? also some help as to engine height both for the outer engines and the center engine would be appreciated.
blueprint is offline
Old 01-01-2010 | 04:56 PM
Sounds really cool. Any pictures?
Maritime_Eng is offline
Old 01-02-2010 | 02:07 AM
I had a triple engine cat ,and a quad engine (and now I run this setup on my twin engine cat ),we set up the left and right mounted engines with the propellor tip running 1 to 1 1/2 inch in the tunnel,we found this on several racing cats with triples ,the height depents on a lot of things ,but on your boat that has a huge notch ,I would start with the center propshaft 1 inch above the bottem to see if there,s enough water pressure ,and then work up with 1/4 inch at a time adjustments.
The center engine on that triple boat was 2 inch above the lowest point of the side sponsons ,and had always enough water pressure .
Off course when you run external pick ups ,you won,t have water pressure problems when adjusting the engine heights.
I would not recommand this to anyone ,but we did this ...
I tied myseld up with a few ropes ,so I had a good grip when laying between the engines on the aft deck ,so I had a good vieuw on the lower units ,let my nephew drove the boat up to 100 mph on 100% flat water ,so we could adjust the engines so that all the water in front of the gearcases was going just under the bullets ,right into the water pickups ,and I could clearly see the upper cones free from the water .
Its not something I would do again ,cause its kinda scary ..
stirling is offline
Old 01-02-2010 | 03:36 AM
bor's Avatar
bor
Jesus Stirling I don,t know you where that crazy !
That must be a lot of years back when you was young ,if youre still interested we can do the same thing on the p21 ?!!
bor is offline
Old 01-02-2010 | 07:31 PM
I tried to get in touch with someone at motion about a new 35 with trip 300s. I emailed and called no one ever called me back or replied.
Velocity Tom is offline
Old 01-02-2010 | 08:22 PM
I'd imagine most of your fillings would be rattled out with those outboards turning 6k+ only inches from your head!
AO31 is offline
Old 01-02-2010 | 08:54 PM
glassdave's Avatar
Neno the mind boggler
was it originally a triple engine boat? something to keep in mind, when you mount any outboard directly in the tunnel the mid case takes a huge beating unless you put a pod in to deflect the water.
08 OPA High Points Champion
glassdave is offline
LubeJobs42's Avatar
Call Larry at Xtreme marine. He is the best there is in Motion set up. He set up more then anyone else. 954-610-2260. Don't drill a thing without talking to him!!!!
LubeJobs42 is offline
Old 01-02-2010 | 09:36 PM
DirtyMoney's Avatar
Second that!
DirtyMoney is offline
Old 01-03-2010 | 07:20 AM
Default Motion 35
yes larry is really tops, he's helping me a lot. glassdave yes i'm going to build a water deflector for the middle engine, as instructed by larry too.
