Discontinued dash trim kits...
Old 01-01-2010 | 08:09 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Discontinued dash trim kits...
Just a precursor... I have nothing to do with the seller or these kits.
I saw one of these dash kits several years ago on a truck that I was contemplating buying. I did a LOT of research and legwork to find out that DeeZee marketed them under the name "DashFormz"; and payed a small fortune to locate and get one for my F-350. The BURLWOOD matches the factory wood in my 2000 Ford nearly perfect.
DeeZee has now discontinued them. They have very few, if any left.
However, this guy has a couple of them left on eBay.
http://motors.shop.ebay.com/lostcont...1&_from=&_ipg=
These kits are plastic, but are not the typical "Advance Auto" flat stick on kits. They are molded for your specific dash. These are the nicest kits you can find less an actual wood kit, which is VERY expensive.
This link will help you determine which one might fit your truck:
http://business.deezee.com/dashkitsdirect/index.htm
I just bought his last two kits for my Tahoe and will probably have one of them custom painted.
Sydwayz is offline
