What to set the rev limiter to on an hp500 carb'd? >
Old 01-03-2010 | 02:25 PM
86Rette's Avatar
Default What to set the rev limiter to on an hp500 carb'd?
Just bought an msd 6 system for my hp500 carb'd. I know the stock merc rev limiter is set for either 5450 or 5350 but I have heard of people bumping it up. Also has anybody messed with tuning the msd with a laptop?
oops, I'm using my dad's laptop and just realized I'm logged in to his account. this is disturbedvelo22
86Rette is offline
Old 01-03-2010 | 04:26 PM
Sea-Dated's Avatar
I thought stock 500's had a 5200 redline....
Sea-Dated is offline
Old 01-03-2010 | 04:52 PM
blue thunder's Avatar
It would depend on if the valve springs were stock hp500 and how many hours on them. If the springs were decent aftermarket with low hours and set up right, 5500rpm would be my number. That engine can make power up close to that level with an upgraded valvetrain. Stock, used springs, 5000rpm would be safe.
blue thunder is offline
Old 01-03-2010 | 05:08 PM
i believe the limiter is at 5250. I had a carbed 500HP i took the rev limiter off and would Run 5600rpm's all day long on, the thing was the best motor ive ever owned, bullet proof
Boomer35 is offline
Old 01-03-2010 | 06:52 PM
Thunderstruck's Avatar
I've run mine up to 5600 rpm for 5 years with no issues.
Long time cult member.
Thunderstruck is offline
Old 01-03-2010 | 07:06 PM
the springs have 50 hours on them and they are springs recommended as stock replacements. I'm pretty sure (at least its what the rpm gauge is reading) the motor is buzzing 5450 with the stock ignition. Did you guys set the distributer up like the stock?
DisturbedVelo22 is offline
Old 01-03-2010 | 07:24 PM
BTW my motors floated the valves with the stock lifters/valve springs at 57-5800. Probably need to stay below that.
Old 01-03-2010 | 07:55 PM
Gizmo's Avatar
Are we having fun, yet?
Thunderstruck, What props are you running?
Jay
Gizmo is offline
Old 01-03-2010 | 10:55 PM
So stock replacement valve springs i should be all good at 5600?
Old 01-04-2010 | 02:22 AM
Recommended WOT RPM of the 500HP is 4800-5200rpms. The rev limiters are supposed to be at 5350rpm, but vary somewhat and also tachs can be off. If you have TB IV ignition, the rev limiter is a separate part and can't be changed. If its a TB V, then I think you can have the limiter in the ECM changed.
Griff is offline
