Go Back  Offshoreonly.com > Owners Forum > Checkmate
-2 Imco shorty results on 253 hulls? >
Old 01-08-2010 | 06:13 PM
253checkmate's Avatar
Default -2 Imco shorty results on 253 hulls?
Anyone running a -2 shorty on their 253 Convincors? Looking for how much speed was gained vs. stock height lower. I am currently running a stock height Xr lower w/28p stock Bravo 1 prop reaching speeds at or above 90 mph gps.(current gps head only goes to 90) Any planing/handling issues? Thanks, Chris
253checkmate is offline
Old 01-08-2010 | 06:42 PM
What kind of power do you have? That is pretty impressive.
specialk is offline
Old 01-08-2010 | 06:44 PM
glen george's Avatar
Im running 253 convincer with a -2 imco lower, I did not gain any speed but my tracking and handling improved. I was told that using a nose cone on boats that run less than 80mph slowed them down, i think they may be right. I turn a BBlades 28 bravo 1 at 52-5300 rpm at 75+. What engine combo are you using to see speeds above 90mph?
glen george is offline
Old 01-08-2010 | 06:56 PM
The engine is a custom built 496 Procharged R-tech intercooled gen 6 making 825 hp at 6200 rpms. Running hd coupler to 1.5 ratio XR drive with billet cap and Imco full hyd. steering.
Old 01-08-2010 | 07:05 PM
Nice ride, any pictures.
Attached Thumbnails -2 Imco shorty results on 253 hulls?-065.jpg   -2 Imco shorty results on 253 hulls?-064.jpg   -2 Imco shorty results on 253 hulls?-089.jpg
-2 Imco shorty results on 253 hulls?-078.jpg   -2 Imco shorty results on 253 hulls?-100.jpg
Old 01-08-2010 | 10:40 PM
What is a -2 drive. Does that put it lower in the water or raise it? I feel I have a slipping issue due to my drive to high and trying to educate myself a bit and explore options to correct condition.
specialk is offline
Old 01-09-2010 | 04:24 AM
Vinny P's Avatar
I hate the winter!!
A -2 lower is shorter lower. It means that it will raise the prop shaft height 2" higher than a standard length lower. Generally, raising your prop shaft height will create more slip, especially trying to plane or turn. So, if you are experiencing handling issues with a standard length lower, adding a -2 will most likely only make things worse. As they say, a picture is worth 1000 words. You can easily see the difference between a standard and a -2.
Your problem can be a number of things. Prop shaft height , type and condition of prop, anything mounted under the hull in front of the drive, to name a few that come to mind. If your drive is too high, the fix is an easy one. You can easily add drive spacers. The are sold by most everbody in 1/2" increments.
Vinny P is offline
Old 01-09-2010 | 08:19 AM
Thanks for the clarification. I was thinking along the right page but wanted to confirm.
specialk is offline
Old 02-04-2010 | 04:45 PM
Default -2 lower
I had a 2001 checkmate 27br I bought the boat used with a -2 imco lower the boat had a stock 500hp efi I also owned 1996 253 and 1996 22 so I no how to drive a checkmate I hated the imco lower the boat ran 66 on gps I put a bravo lower on the boat with the same prop I it ran 69 on gps at lower rpm
checkmate 500 is offline
