Filling Mechanical Fuel Pump with Gear Oil >
Old 01-12-2010 | 08:24 AM
sleek1's Avatar
Default Filling Mechanical Fuel Pump with Gear Oil
How much gear oil do I put in the mechanical fuel pump resevoir? This is for a 500 EFI and bolts to the sea water pump.
sleek1 is offline
Old 01-12-2010 | 08:33 AM
there should be a line or groove machined in the side of the resorvoir to use as a guide. Generally I just fill mine to the same level it was (because I know mine doesnt leak) after sucking out the old stuff and cleaning it. Hope that helps.
eichhoma is offline
Old 01-12-2010 | 08:48 AM
t500hps's Avatar
21 and 42 footers
Do you have it off? I pulled mine last year after hearing about a number of failures. Those dam things have one little hole at the TOP. I pulled mine, drilled and tapped a hole at the bottom to create a drain. Now I can drain them, and re-fill til oil comes out the top hole without removing them.
t500hps is offline
Old 01-12-2010 | 01:26 PM
sleek1's Avatar
Yes, I have it off. I didn't see any machined line, but I THINK I can see the old "scum" (for lack of better terminology) line. I thought about just filling to the old line, but like to be sure. Also, what am I supposed to use on the hard fuel line (threads) that screw into the brass elbows... Loctite? #?
Thanks, hope I'm being clear enough.
sleek1 is offline
