Stainless braided hose question >
Old 04-15-2002 | 12:23 PM
MrCIG's Avatar
Charter Member#330
Default Stainless braided hose question
I want to put stainless braided hose from my thermostat housing to my headers, it is 1" hose.
What dash # would be equivelant to 1" hose?
MrCIG is offline
Old 04-15-2002 | 12:51 PM
blown formula's Avatar
I believe that would be AN-12... very expensive stuff!!
blown formula is offline
Old 04-15-2002 | 01:52 PM
I think it's usually closest to multiples of 1/16". 1" ID is about -16. Double check your measurement, 1" sounds big for a thermostat outlet. Remember it's the inside diameter of the hose your measuring. The S/S line is kind of an overkill for that application. You could just use the braided hose covers and clamp covers that Merc uses on their motors.
I've also used "Push Loc" hose with brass JIC fittings. It's not as flashy as the S/S stuff, but it's a lot cheaper and makes for a very clean looking installation.
Gary
Gary Anderson is offline
Old 04-15-2002 | 02:33 PM
turbo2256
Old 04-15-2002 | 05:30 PM
MrCIG's Avatar
Charter Member#330
Thank you,
I will double check but I believe the hose said 1"
So we all agree it -16 right?
Mark
MrCIG is offline
Old 04-15-2002 | 06:48 PM
Turbojack's Avatar
From Aeroquip catalog
#4 = ..25 hose id inches
#5 = .31"
#6 = .38"
#8 = .50"
#10 = .63"
#12 = .75"
#16 = 1.00"
#20 = 1.25"
Turbojack is offline
Old 04-16-2002 | 05:28 PM
MrCIG's Avatar
Charter Member#330
Now I confused I have a book at home and it says -18 is 1"
But I did double check and it is 1" to the CMI's from the stainless thermostat housing.
Any one else care to guess.
Thanks again
MrCIG is offline
Old 04-16-2002 | 08:56 PM
I used -12 from the thermostat housing to Gill manifolds. I do not think you have to go any larger. Take a look at the size of the fittings you will be threading your adapters into. The hose will not flow anymore than can fit past the restriction in the adapter.
dckrafft is offline
Old 04-16-2002 | 09:01 PM
Keith's Avatar
CBPBA's Walmart Greeter
Gary,
Where did you buy the braided hose covers you referred to? Is it called that exactly? I'm having trouble finding it.
Thanks in advance.
K2
CHESAPEAKE BAY POWER BOAT ASSOCIATION
'http://www.cbpba.com'
"Experience is something you don't have until just after you need it."
Keith is offline
Old 04-17-2002 | 12:23 AM
bck's Avatar
bck
Charter Member#568
Kelley,
You can get braided hose covers through mail order places like Summit or Jegs. Local auto parts stores that deal with high perf parts or have a big selection of dress up items should also have them.
Straight bottoms and flat decks
bck is offline
