What Trim Fluid to use ? 30wt oil or Trans fluid?? >
Old 01-19-2010 | 10:15 PM
Strip Poker 388's Avatar
Rob
Question What Trim Fluid to use ? 30wt oil or Trans fluid??
Is it better to use 30wt motor oil which was on the tag on the new trim pumps, or is Trans fluid OK?
I have Valvoline straight 40wt and Valvoline Max life Dex/Merc trans fluid.The trans fluid is what I have been running in my steering and trim tabs.
My trim system has been drained when I striped the boat. It had trans fluid in it but it was dark.It was this way when I bought it.
I would appreciate your thoughts.
also what weight is the Dex/merc transmission fluid??
Rob
Attached Thumbnails What Trim Fluid to use ? 30wt oil or Trans fluid??-tickfaw-200-5-09-045-large-.jpg
Strip Poker 388 is offline
Old 01-19-2010 | 10:28 PM
HotPursuit's Avatar
Rob I have allways used amsoil trans fluid in everything but the drives and engines. My pumps and rams have lasted forever in all the boats I have run.
40 wt oil is for lawnmowers.
HotPursuit is offline
Old 01-20-2010 | 08:00 AM
I agree. AMSOIL Trans fluid.
07DominatorSS is offline
Old 01-20-2010 | 08:15 AM
hoozeyurdaddy's Avatar
I think trans fluid is 15W oil, which is the same as power streering oil, yout dex/merc oil should work just fine.
hoozeyurdaddy is offline
Old 01-20-2010 | 12:18 PM
Rob
Lightbulb
Looks like everybody is using trans fluid.thanks for the replys.
Anybody else?
Rob
Old 01-20-2010 | 01:50 PM
I use Merc motor oil without any problems. I always figured it's one less thing to carry onboard and easier to find if you get stuck.
floatingphil is offline
Service manual says to use 30wt.
tbanzer is offline
Old 01-20-2010 | 01:54 PM
Brad Zastrow's Avatar
I run the straight 30W oil Mercury reccomends. Trans fliud is much thinner. I only use what weight oil manufactures reccomend in my cars, trucks and boats. I am funny that way.
Brad Zastrow is offline
Old 01-20-2010 | 06:28 PM
HotPursuit's Avatar
Mercury don't even run there oil in drysump 6s. And as far as I know they don't refine any!Amsoil comes in different weights.. Huber or Bam transmissions would never last under big power with 30 WT mineral oil recommended by Borg Warner.
Old 01-20-2010 | 08:05 PM
PAST DUE's Avatar
mercruiser power trim /power steering fluid that way you know you are using the right stuff
PAST DUE is offline
