Cleaning the gunk off the motors >
Old 01-23-2010 | 04:32 PM
Default Cleaning the gunk off the motors
What's the best way to wash your motors off? I've got a build up of grime starting to appear and I want to clean them up before it gets bad.
Austin is offline
Old 01-23-2010 | 04:37 PM
I used to use Castrol Superclean, but I can't seem to find it anymore. Worked great though...
Super Castrol Cleaner or another one called Grease Lighting Degreaser are both available at Pepboyz (and probably most local auto shops), and a product called Purple Power is pretty good and available at Lowes.
If you use any of the above products make sure you "test" them on a small area or other material first. All of them should work, but you might want to heavily dilute them so you don't stain your bilge comp. or take the point off of your motors!
wjb21ndtown is offline
Old 01-23-2010 | 04:58 PM
So it's OK to get the motors wet using fresh water??
Austin is offline
Old 01-23-2010 | 05:24 PM
Strip Poker 388's Avatar
Rob
becarefull of the harsh cleaners,I used 409 once,it bleached out a AN blue fittingIve used gunk on oil spills, it just makes the bilge stink
I just use Windex with extra amonia added.just dont let them get dirty
Rob
Attached Thumbnails Cleaning the gunk off the motors-outdrive-1-14-2010-051-large-.jpg
Strip Poker 388 is offline
Old 01-23-2010 | 05:52 PM
rush's Avatar
Don't use chemicals on your engines, it will ruin the Finnish. It will ruin aluminum.
rush is offline
Old 01-23-2010 | 06:06 PM
sleek1's Avatar
Even Windex?
sleek1 is offline
Old 01-23-2010 | 06:34 PM
Rookie's Avatar
Strip, your bilge is just SICK!
Rookie is offline
Old 01-23-2010 | 08:09 PM
Strip... I think I se a spot on one of those! Just kidding. I see you take very good care of your motors. So- just to be clear... I can spray my motors with cleaner ( simple Green) and then hose them down with water?? Then after that spray them with CRC 656.
Austin is offline
Old 01-23-2010 | 08:16 PM
Sick Stinger's Avatar
Brotherhood #1
Auston stuff called tuff stuff clean the hair off a rhino drys out your hands but doesnt hurt finishs of any soft wet surface spray with tuff stuff lit sit 5-10 to break grease grime i use a brissel brush or rag depending on finsh then hose off like new!
-Mike
Sick Stinger is offline
Old 01-23-2010 | 08:18 PM
I use Gunk degreaser. It will not hurt anything....paint, polished alum., etc. Just don't spray water right at the distributor or straight in the flame arrestor. Everything else is OK to get wet.
Eddie
Young Performance is offline
