454 Flywheel help.
Well still trying to get this motor together. Ran into another problem.The flywheel I have will not bolt to the Bravo 1 flex plate.Can someone direct me to the proper flywheel? Here are the numbers on my block. It is a Gen V 454. Thanks Mike.
It would be better or Safer to find you a part number for a NEW flywheel if You could post your engine serial number.
Here is some info on where the serial # could be found on a MerCruiser engine.
https://appcenter.mercurymarine.com/...Locator-mc.jsp
Mike,
If the flywheel you have is the correct one for the engine, it would be a pretty easy job to redrill it for the correct bolt pattern for your coupler plate. If you do decide to go with a new flywheel, keep in mind that the GenV and newer engines are balanced differently than the MKIV's plus the flywheel for engines with cast crankshafts is balanced differently than the one for engines with steel crankshafts.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
Mike,
Bill Koustenis
Waldorf Md
Bill Koustenis
Waldorf Md
Mike,
Bill Koustenis
Waldorf Md
Bill Koustenis
Waldorf Md
I will look up that flywheel number in the morning at the shop and let you know if it is correct for your engine.
