ECU reprogram >
ECU reprogram
ECU reprogram
Old 01-24-2010 | 04:26 PM
Default ECU reprogram
I currently have a 2000 502 MPI with a Vortec supercharger. The motor runs idles and has performed perfectly for about 150hrs. I would like to add a bigger camshaft more suitable for a boosted engine. Curently its using a MEFIV ECU. Looking for iinformation on a facility to tune the ECU forthe new configuration.
tbanzer is offline
Old 01-24-2010 | 04:48 PM
t500hps's Avatar
21 and 42 footers
Do not send off the computer for this.....send the entire engine!! (unless you want the practice of building an engine TWICE. It's just too risky IMO)
Mark Boos at Precision Marine does great work.
t500hps is offline
Old 01-24-2010 | 07:10 PM
I have done both. The first time I sent the computer to Arizona Speed and Marine it worked well for about 250 hours and I freshened the motor. The second time I had Tyler Crockett dyno the motor he does it fully dressed as it is installed in your boat, exhaust and all from the first pull to the last we picked up 200 HP and a little better in tourque. Dyno is the way to go.
RBeyer is offline
Old 01-24-2010 | 08:12 PM
You definitely should tune it on the dyno. I can dyno and tune mefi ecms. Give me a shout if I can help.
Eddie
Young Performance is offline
Old 01-26-2010 | 11:26 AM
Eddie Tuned mine on the dyno. Iron heads, .040 over with a Bob Madera cam, 840 hp!
kennyo is offline
Old 01-27-2010 | 08:42 AM
ZXXX Donzi's Avatar
Eddie tuned mine on th dyno too. It made 942hp. Oh yeah, he built the engine as well. I have had two really good seasons on it so far.
ZXXX Donzi is offline
Old 01-27-2010 | 09:59 AM
Smitty's Avatar
Mark at Precision is the guy. He has tons of saved calibrations so he will find one that works for you.
Speaking from personal experience, if you want more horsepower, pull the heads and get them ported and cleaned up. Call Bob Madera at 585-654-8583 for a custom cam.
Then build a crate and send your completed motor down to Mark at Precision, where he will dyno tune it to run perfect and make the most power.
I have used him personally so if you have any questions, PM me.
Smitty
Smitty is offline
Old 01-27-2010 | 04:36 PM
Default Fixx
+2 for eddie,,Bills(ZXXX) 26 zx will bust 102 mph....
FIXX is offline
Old 01-27-2010 | 07:20 PM
ZXXX Donzi's Avatar
Yes sir Mike. The water is the real dyno. Which makes the case for tuning in the dyno AND the boat.
Old 01-27-2010 | 08:46 PM
Default Fixx
Ummmm, where's the 24 cylinders are better then a ?
FIXX is offline
