Listed my Fountain >
Listed my Fountain
Listed my Fountain
Old 01-27-2010 | 11:19 PM
2112's Avatar
Default Listed my Fountain
I Ordered it new and dumped $ into it like I had a printing press. I have hung on due to the blood sweat and tears but It needs a home where it will get used.
http://www.offshoreonly.com/classifi...o32567-en.html
Had all the factory weak areas in the deck professionally repaired and reinforced with new deck stringers and side hull stringers . Also corrected the windshield that is 2 inches further forward (on all 32's) on the starboard side.
Drop in your GM power or I can do it for you.
Drives thoroughly sorted out starting with quality Diesel gears and HD Gimbals.
Yes the boat only has 7 freshwater hours on it.....long story.
2112 is offline
Old 01-28-2010 | 07:36 AM
Pwrbt33's Avatar
WOW!!! She is beautiful. Sorry to hear you getting rid of her.
Good luck.
John
Pwrbt33 is offline
Old 01-28-2010 | 12:28 PM
2112's Avatar
Good luck.
John
Thanks, Too many irons in the fire and I could use the space. She needs a home where she'll be enjoyed beyond being a Garage Queen.
2112 is offline
Old 01-28-2010 | 10:23 PM
Petesflht's Avatar
where you at in washington? am just north in british columbia? thanks
Petesflht is offline
Old 01-28-2010 | 11:50 PM
2112's Avatar
Yes, South Puget Sound, 35 miles south of Seattle.
2112 is offline
Old 02-03-2010 | 08:24 AM
Reggie's Avatar
Beautiful boat
Reggie is offline
Old 02-03-2010 | 08:34 AM
Ok I have to ask, 7 hours on a 98?
Wildman_grafix is offline
Old 02-04-2010 | 10:53 PM
2112's Avatar
Long story. In a nutshell, Ordered the boat, Filed for divorce before it arrived. Argued with the factory for two years over poor gelcoat on deck, Got boat back from factory late 99' Recovered financially enough to start project, Rigged it for Fords, Got it in the water 02' saw problems with deck in rough water, took boat apart, put in custom Glass shop for 14 months Fixing all the problems we could find, Got boat back and by that time I wanted a Gladiator.
2112 is offline
Old 02-06-2010 | 09:19 AM
Bad Girl's Avatar
Default Paint question
So the deck gelcoat faded and you put clear over the blue gelcoat to keep it shiny?
47 Lightning SE
Bad Girl is offline
Old 02-06-2010 | 12:01 PM
2112's Avatar
Not even close.
Fountain doesn't clean the molds between lay-ups. You don't see all the defects and garbage on white boats or boats that get painted.
I paid $4500 to have blue gel. The hull was good. The deck was abysmal. It was beyond fixing. It was exactly like the black boat that guy from Europe was complaining about and all the fanboys blamed him for buying a used boat.
Mine was abysmal from day one (brand new boat). White and yellow gel splatters in the blue. Pits and voids.
My dealer argued for me from day one. After 2 years, Fountain drove out to the west coat and picked up the boat which I kept in heated storage. Still a brand new boat. They painted the deck with Imron and called it good. "you are on your own". Of course the Imron was also terrible. Burned, Missing in spots etc.
I noticed some issues when Taking the boat apart to paint it yet again, I gave up on Fountain, We found the hull to be well constructed the deck had some serious shortcomings. Like being paper thin in areas and having the windshield almost 3 inches further forward on the starboard side than on the port side, Kitchen cabinet framework held in with 1 piece of fabric etc.
It then spent 14 months in a custom glass shop/boat builder having those weak areas reinforced, Stringers added to the underside of the deck, and extra bulkhead added in the center under the dash, new additional horizontal stringers added from the back bulkhead to the front bulkhead on the sides of the hull. We addressed every single problem.
Yes we fixed the crooked windshield too. BTW The side acrylic "glass" of the cockpit was much longer on the starboard to compensate for the crookedness. Replaced all that too.
All on a new boat.
See Post # 14
http://www.offshoreonly.com/forums/g...believe-2.html
Exactly how my boat was. Again, Brand new, not used.
2112 is offline
