power steering cooler >
Old 01-28-2010 | 06:20 PM
Default power steering cooler
I searched this site regarding the need of a power steering cooler for a full hydraulic steering system. I would like to run the return line thru a tranny cooler with forced air flowing around the cooler. Would a small 8" oil cooler cool better than the tranny cooler, has anyone ran a tranny cooler?
alecsammy is offline
Old 01-29-2010 | 02:12 AM
I would not use a air cooled cooler. Use a 2" X 8" oil cooler. This will get the job done. You really don't get enough cool air flow for an air/liquid cooler to work to it's max capacity. The p/s fluid actually gets pretty hot because of the pressure. They can spike up to 2000 psi when the wheel is locked to one side. This generates a ton of heat. You should have no problem finding a Sen-dure or similar cooler. I know CP Performance and Eddie Marine both have them. Good luck.
Eddie
Young Performance is offline
Old 02-08-2010 | 04:29 PM
Commercial Members
With the experience of Young Performance, it's hard to argue his logic. But you can get a plate cooler with up to 30 plates from us. So if you're using forced air, maybe a plate cooler will work. if the pressures are where Eddie at Young is stating, I'd suggest a high pressure unit. If you know something about the temps and pressures currently in the system, forward that either in thread or to my email and I'll see if I can size the cooler for you.
Russ
Mr. Cool is offline
Old 02-08-2010 | 09:02 PM
fireboatpilot's Avatar
RIPSTA Racing Team
You already have cool water running thru the engine comp to oil coolers and exhaust. Why would you want to use some sort of forced air coolin rig that needs a fan that can fail and leave you with no cooling and if no fan then when your not moving, no cooling. Why re-invent the wheel? By the way you cool on the return side not the pressure side so no high pressure cooler would be needed.
fireboatpilot is offline
Old 02-08-2010 | 10:50 PM
2112's Avatar
Maybe he want to make sure the raw water is it's coldest for the oil cooler and going air cooled will get one more heat sink out of the line.
At least that is why I considered it.
Oh, did not want an additional water line in the bilge with a 2 stage water pump
2112 is offline
Old 02-09-2010 | 01:13 AM
Just wanted to clear up that I meant the high pressure is what causes the heat. Not that the cooler has to be able to handle that amount of pressure. I guess I should have specified that the cooler goes on the low pressure return side.
Thanks for pointing it out.
Eddie
Old 02-09-2010 | 01:48 AM
tcelano's Avatar
+1 on why would you consider using air to cool in an enclosed space, when you already have water flowing that is 800 times denser and on a nice summer day, starts off 20-40 degrees cooler? When designing crewboats and tugs that frequently work in places where you are stirring up the bottom, and don't want to suck raw water, we use "keel" or "grid" coolers that exchange heat either against the hull or externally. On a submarine or Navy ship, even a lot of the electronics are water cooled.
tcelano is offline
Old 02-09-2010 | 09:44 AM
I have a spare power steering cooler for $50.00 if interested. It came off my 496ho with about 12hrs on it.
22 DAYTONA is offline
Old 02-09-2010 | 08:38 PM
Commercial Members
Eddie
Being the new kid around here, I was worried about stepping on toes. :-). Glad we're all on the same page.
Mr. Cool is offline
Old 02-09-2010 | 10:40 PM
It's all good brother.....don't sweat it.
