Trailer Guide Poles
Old 01-30-2010 | 09:45 AM
BONDO10's Avatar
Cool Trailer Guide Poles
I'am Looking For Any Info On Verticle Guide Poles For A 382 Fastech Trailer. Not Goofy Or Homemade. Something Maybe A Little Trick. ????????
BONDO10 is offline
Old 01-31-2010 | 06:32 AM
GO4BROKE's Avatar
http://www.rockettrailers.com/PartsB...GuidePoles.htm
I don't know of any trick parts.
[img][/img]
GO4BROKE is offline
Old 01-31-2010 | 01:28 PM
Barrydet's Avatar
Default Here is an idea...
I mounted 2" receiver tubes on both sides of the frame rails behind the rearmost axle facing outward. I took a 2"o.d. pipe, 8ft long and welded to a 18" long square tube. This creates a removable guide pole that fits into the 2" receiver on the trailer. I galvanized all the metal parts. Drill a 5/8" hole in the square tubing at the proper place and use a normal receiver pin to hold the pole in place while mounted upright in the receiver tube. Place a carpet covered 2"i.d. pvc pipe over the metal pipe and you have a nice looking, strong, removable guide pole assembly. While trailering, the guide poles ride up front in brackets mounted on the bow winch post and traler crossmember. The poles are riding under the bow of the boat and securely fastened to prevent movement.
I know, you are thinking "Why 7-8 ft tall?" Your long trailer extends so far into the water, that you need the height to contact the rub rail of your boat during approach.
I would encourage you to stay away from the aftermarket guide pole kits that mount with u-bolts and clamps. The clamps are not tight enough to prevent "pushover" when your big boat contacts them while loading. That would create a real problem and embarrasement.
Hope this helps with your project.....
Barrydet is offline
Old 02-01-2010 | 06:05 AM
BONDO10's Avatar
Barrydet, Thanks For The Info. Sounds Like A Pretty Good Set-up. Any Pics? Thanks,jeff
BONDO10 is offline
Old 02-03-2010 | 01:36 AM
jonyb's Avatar
Try giving Boatmate Trailers a call. 865-273-1100
Maybe they can give you an idea.
jonyb is offline
Old 02-03-2010 | 05:34 PM
seafordguy's Avatar
I have a set off my Cafe trailer that you can have, but I doubt it is worth the shipping.
seafordguy is offline
Old 02-03-2010 | 05:43 PM
t500hps's Avatar
21 and 42 footers
My trailer came with the clamp on type mentioned above.....after a couple seasons I decided to put them on this past summer and try them. A) They do need to be nearly 8 ft tall. They will be starting from deep under your bow when you first approach and need to come up to your bow rail. B) the pre-fab clamp-on type will hold a clamp, however, they WILL bend like crap as soon as the boat puts any pressure on them side-to-side......I took them back off after 2 trips cause all I did was bend the crap out of them.
t500hps is offline
Old 02-04-2010 | 02:36 PM
seafordguy's Avatar
That's cause you can't drive worth a ****....
