Any place in southern Jew Jersey fix Ez Loader trailers? >
Old 01-31-2010 | 07:50 PM
Default Any place in southern Jew Jersey fix Ez Loader trailers?
This is the trailer that came with my Baja. It is rusted at the center of both dual axles.The one side bent from weight of boat.It will need new hangers,springs, bogies. Axles are good .Will need new spindles. Are there any repair shops in Southern New Jersey that fix Ez Loader trailers?
89 Baja 250 is offline
Old 01-31-2010 | 08:50 PM
I have a shop on Long Island and I can rebuild the frame. not a big deal. Check the rear of the frame and middle bottom of the x members. hit them with something hard and make sure the metal still has a ring to it. If it doesn't there is rust in there as well.
Spindle aren't a problem to change but sometimes it makes sense just to replace the axles.
If you are interested give me a call
631 647 7792 - shop
I am open 8 to 5 during the week and 8 to noon on Sat.
Thanks, Neil
www.ectrailers.net
snogiyogi is offline
Old 01-31-2010 | 09:02 PM
The EZ Laoder is designed to handle a 22' maybe some 23' but that is it. Like the Float on it has 2 - 3500# axles with a 2" ball. It has 32 rollers which means it is a 4700# capacity. The exact model is a EZ 22T4700
Take a tape with you and measure ht etrailer tip to tip and in order to fit your boat the trailer has to be 27' overall length. If it is shorter the boat won't fit properly
Neil
Old 01-31-2010 | 09:05 PM
Neil. I am 140 miles from you in Westville N.J. I don't think the trailer would make it to your shop.I have been looking at used ones. $2000 is the cheapest I have found for a used 27 foot boat trailer. I thought this one could be fixed for around a $1000 bucks. If I were closer to your shop . I would be there tomorrow. Thanks Mike.
Old 01-31-2010 | 09:17 PM
The boat is 25 foot from front to transom. Plus 2 foot of swim platfrom. It seems to fit perfect on trailer. Here is a picture of it on the EZ Loader. Look to big? Thanks Mike.
Neil[/QUOTE]
Old 02-01-2010 | 03:24 PM
bowtie's Avatar
I do trailers down near the shore.I am outside of Sea Isle City and can pick it up also. Chuck 609-231-3525 or [email protected]
bowtie is offline
Old 02-01-2010 | 04:59 PM
You do know Sea lion trailers is on creek road in Bellmawr ? no retail but maybe run it by and see if they can match up frame rail then have Nuwave marine do the work in Deptford . Tell them Larry sent you
activatorf1 is offline
