4KW Hot Water Heaters
Old 02-01-2010 | 03:59 PM
rjr
Default 4KW Hot Water Heaters
My Formula 382 does not have a hot water system so I was thinking of putting an inline tank-less hot-water heater in the cold water line. The problem is that I have not found one that doesn't exceed the capacity of my 4KW generator. Any recommendations or suggestions would be appreciated.
rjr is offline
Old 02-01-2010 | 04:17 PM
why do you want to "heat", "hot water". sorry I couldn't resist. Just "water heater"
Good luck though
My Addiction is offline
Old 02-01-2010 | 06:38 PM
Here's a 2.4 kw model
http://www.eemax.com/EX2412M?searche...rch_highlight1
DonziGreg is offline
Old 02-02-2010 | 09:03 AM
bcfountain's Avatar
Registered User
if you are just looking to wash hands or maybe a bird-bath shower you could probley use a e-max point of use heater.2.4kw ,115v.if you could find a 220v e-max that would be the deal.these heaters are small and lite.5" wide,9"tall,about 2"thick.
bcfountain is offline
Old 02-03-2010 | 11:12 AM
rjr
I stand corrected it's a water heater! Also, thanks for the link. That looks like the one.
rjr is offline
