BW, C-72 Rebuild >
BW, C-72 Rebuild
BW, C-72 Rebuild
Old 02-02-2010 | 07:07 PM
Default BW, C-72 Rebuild
To make a long story short I have a good frined of mine (GM Tech) who was going to rebiuld my tranny's. He is gone and I am left with one torn down and cleaned and the other one still together. I have the rebuild kits along with the manual that I ordered with the kits. He just dropped them off at my shop and I haven't had a chance to even look at them yet to see what I'm in for. Just thought I would get a heads up before I move forward this weekend.
I can't imagine this being a real difficult task. There is no valve body - correct? Any insight along with do's and dont's would be greatly appreciated. Tranny's are something I typically would farm out to an expert however given the area in which I live experts are difficult to find. Not only that I am interested and enjoy learning new things.
Thanks,
John
getrdunn is offline
Old 02-02-2010 | 07:52 PM
I rebuilt one of my tranny's last year. not a big deal read the manual carefully. Take your time. the manuals are pretty well detailed it was my first tranny job ever. i was afraid before I did mine but now I wouldn't think twice it is as easy as it can get. pay attention to the c clips. the thicker c clip goes between the forward piston and drive plates. good luck
amazing1 is offline
Old 02-02-2010 | 08:12 PM
MrCIG's Avatar
Charter Member#330
Get a hold of Steve Nykamp on the board his buddy who has a 36 Apache rebuilts transmissions. They are out of Grand Haven
Mark
MrCIG is offline
Old 02-02-2010 | 08:15 PM
BWs are so simple let me know if I can help. 19 years exp.
Driveguy is offline
Old 02-02-2010 | 09:12 PM
Default Fixx
Their a piece of cake! the only thing i would reccomend is to extend the pick up tube for the pump if it hasnt been done already.. most of the oil ends up in the back of the trans when the boat is on plane and just keeps the tranny from starving for oil..
FIXX is offline
Old 02-02-2010 | 09:24 PM
These are some good pointers and I appreciate it. I have a feeling that I will be back on here Monday aknowledging the simplicity of such. I'm actually looking forward to it. It's the middle of a cold winter and time to broaden my mind. Thanks for sharing tips and offering help.
John
getrdunn is offline
Old 02-02-2010 | 09:26 PM
Mark
Is this Blue Moon your refering to? If so he is the guy who use to run a checkmate way back when out of GR. Is he on this board? I know he has a transmission shop also.
getrdunn is offline
Old 02-03-2010 | 10:20 AM
the tranny your working on is otherwise known as a velvet drive. extremely simple, been in production since ww2, in various versions and sizes. basically a planetary transmission. will need good snap ring pliers, pay particular attention to order in which clutch plates go in. there is what they call the selector valve, make sure it is not scored, and check the oil pump for scoring also. it basicly has 2 planetary gearsets. forward and reverse both identical. your biggest enemy will be dirt and varnesh. lacquer thinner or acetone will take care of that. having one that is still assembled. in dual instalations, the shift cables will be oposite on each. side for proper rotation. I worked on these when in USCG
doggiedave is offline
Old 02-03-2010 | 10:43 AM
Cool,
I'll let you guys know how it goes after the weekend.
Thanks,
John
getrdunn is offline
Old 02-03-2010 | 10:47 AM
P.S I ment tell you that if you get stumped go to the unit tha is still assembled for clue cards
