Is spinning props in faster??? >
Old 02-02-2010 | 10:33 PM
Default Is spinning props in faster???
Who has run in and out, and has some real numbers for comparison??? I am running a straight bottom, side by side vee........
302Sport is online now
Old 02-02-2010 | 10:40 PM
HotPursuit's Avatar
Only one way to find out. I would put my money on faster with less handling/ control. More rpms because of the blades sharing more H20 from the transom..
HotPursuit is offline
Old 02-02-2010 | 10:45 PM
i know docking is harder, but say running in 2-3's, will the handling be any different???
Old 02-02-2010 | 10:47 PM
Gives more transom lift and less control...
POWERPLAY J is offline
Old 02-02-2010 | 11:07 PM
GLH's Avatar
GLH
Faster in but can't park worth the crap...
Running a Tiger with #6's and one with Bravo XR's before that, back then.
GLH is offline
Old 02-02-2010 | 11:22 PM
Yes!
AO31 is offline
Old 02-02-2010 | 11:35 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
My boat was originally in. Docking sucked, backing up sucked even more. Boat felt loose and squirly when running full tilt.
I changed them to out. Docking is now a breeze, 100% more solid/stable when running, zero loss of speed.
I'd easily gave up 5 mph for the better control if that was the downside, but I didn't. Besides, do you spend more time running WOT or docking?
US1 Fountain is offline
Old 02-03-2010 | 06:26 AM
offshoredrillin's Avatar
Depends on the boat;
first off, turning in creates bow lift, not stern lift. On my tiger it gave me a couple mph throughout the whole power band. the boat still docks fine, I noticed that at cruising speeds, I'm going the same speeds at less rpms, which to me shows the boat being more efficient. I have a 42 tiger and needed the bow to be carried more and went from 74 to 76.8. I just switched the props for a weekend to give it an honest test and loved it, actually the first time it hopped right up on plane convinced me, but i gave it another day to try all situations.
offshoredrillin is offline
Old 02-03-2010 | 07:31 AM
Audiofn's Avatar
Charter Member #232
I think it depends on the boat. I switched my Formula 302 in and picked up about 200 RPM's and I actually liked the way the boat rode better with them in. I also did not have to trim it up as much to carry the bow. Never had a speedo hooked up to know the MPH increase. Docking was slightly more difficult but I think that was just that I did not have the time to get used to the different way things work.
Put your best foot forward!
Audiofn is offline
Old 02-03-2010 | 07:32 AM
yeah turning in is def. more bow lift, i know that is a fact. But, does more bow lift mean more total lift??? I have read somewhere that turning props in is like lifting the x dimension??????? Also have heard that bigger diameter props create stern lift, but if spinning the props in, do they create more bow lift????
