Which CARB Barry Grant VS Holley HP >
Old 02-04-2010 | 07:22 PM
Question Which CARB Barry Grant VS Holley HP
Hey guys,
Just ready to pull the trigger on a couple of carbs for my built 496's. I am at a stand still though trying to decide on the Barry Grant 850 down leg OR Holley 950 HP.
Any input or would be helpful. Need to decide before going to the dyno next week.
Thanks,
John
PS I am leaning towards the BG
getrdunn is offline
Old 02-04-2010 | 10:11 PM
Call pro system carbs before you shell out the cash for new off the shelf. I am on the hunt for a new carb too, and have been wanting to go custom carb because I do not want to set it up. The only problem is everyone I have talked to like Nickerson have been pretty expensive. Pro system is not anymore expensive then off the shelf, and very willing to help. It seems worth a try, and is the route I think I am going tomorrow.
tx911 is offline
Old 02-04-2010 | 10:41 PM
Default Fixx
neither,c&s,, their aerosol carbs are like haveing FI with the throttle response..give them your specs and they will build you a marine version..
http://www.candsspecialties.com/stor...lbillets2.html
FIXX is offline
Old 02-04-2010 | 10:46 PM
C & S looks pretty cool too, but still not that cheap especially if buying two. I sure would like to try one.
tx911 is offline
Old 02-05-2010 | 06:10 AM
I agree, call patrick at pro systems, will custom build for the cost of stock !!! run his stuff on my 1000 h/p top sportsman engines...carbs are spot on out of the box and not nearly as expensive as you would think..bolt them on and go !!!
ezstriper is offline
Old 02-05-2010 | 06:24 AM
I have used both Barry Grant 750 & 850 on my last 496. The 850 was to big. They also make an 825 version now. I bought mine from a guy off Ebay and you can not beat his prices anywhere. At my door in 3 days. They are easy to tune, look great, and run great.
I was sold after my first BG
1BIGJIM is offline
Old 02-05-2010 | 06:41 AM
FORGET about BG, I have used C&S aerosols for 12 years with very good results but a bit expensive. We used Pro System on the last build and are happy with the quality and price (also made more HP). I have 2 BG 850's new with 3 dyno runs on 1 and the other still new in box make you a deal.
brian41 is offline
Old 02-05-2010 | 07:05 AM
Has anyone used quickfuel carbs they look really nice.
baja27 is offline
Old 02-05-2010 | 10:44 AM
BY U BOY's Avatar
I use the BG 825 and at first didn't like it but now I wouldn't use anything else. Very easy to work on.
I got mine from Dean Gellner for a great price.
BY U BOY is offline
Old 02-05-2010 | 11:48 AM
Thanks guys, this really helps. I realize you get what you pay for also. It just sucks when you do these rebuilds and then find out you need to spend more $$$. Carbration is as important as cam selection though.
getrdunn is offline
