HP500 Cam Help >
HP500 Cam Help
HP500 Cam Help
Old 02-11-2010 | 08:25 PM
Default HP500 Cam Help
I have a HP500 carb with a Blowershop 250 (4psi) and a demon carb in a 25 Daytona. I am wanting to put a different cam in it and run 5psi and not turn it over 5400rpm. Any ideas please let me know... Trying to hit 100mph....
ryanmcclaran is offline
Old 02-11-2010 | 10:31 PM
What cam do you currently have? Also I would perhaps look into Mercs cam specs for the 600 sc and pulley accordingly. Their are a lot of Blower guys on the board and will hopefully answer your question a little better. Also PM Griff, he seems to be pretty blower savvy.
getrdunn is offline
Old 02-11-2010 | 11:07 PM
here are my factory cam specs
Crane Gen VI#169611 Grind#HR-284-2S-10IG
Adv 284, 292 at .004” Lift with 1.7 .576 / .598
At .050” 222, 230
ICL 105, ECL 115
LSA 110
And if anybody knows where I can find the factory cam spec for the merc 600sci or the 700sci please send me the info or the link
Old 02-11-2010 | 11:46 PM
What speed and rpms are you at now????? A cam change and another 1 lb of boost may not be enough unless you are already in the upper 90's.
Griff is offline
Old 02-12-2010 | 12:10 AM
it runs right at 90mph at 5200rpm on a stock 4blade 30. I want to upgrade my drive also and I have read that you can gain a few mph from a 1" shorty?? I have a really reliable boat but the motor has 400hrs so Im gonna have the heads done and I want to get some more power but still want the reliability...
Old 02-12-2010 | 12:12 AM
Strip Poker 388's Avatar
Rob
prob will be a custom grind to keep the peek at 5400,come on now just buz that thing,that wil get ya the 1 lb.
what size carb? Dom?
Rob
Strip Poker 388 is offline
Old 02-12-2010 | 12:45 AM
its a 1090 King Demon Marine.
Old 02-12-2010 | 12:48 AM
Rob
cool
Old 02-12-2010 | 06:10 AM
that does not look to be a good blower cam, need a wider lope seperation for the boost to work well, call Bob M.
ezstriper is offline
Old 02-12-2010 | 11:55 AM
You are definately going need more than a cam and a pound of boost. You will need about 150hp more to hit triple digits. Really, you need a better set of heads, cam and more boost.
I would do AFR aluminum heads, custom cam from rmbuilder, and up the boost to about 6#.
Griff is offline
