What should I set my total advance at??? >
Old 02-12-2010 | 01:39 PM
Default What should I set my total advance at???
540 cu in, NA, carburated, 8.8 : 1 compression, iron heads, and always run 93.............
302Sport is offline
Old 02-12-2010 | 01:53 PM
Stormrider's Avatar
JC Performance Engines
Don't you think this question would be better suited in the Technical section???
Stormrider is offline
Sick Stinger's Avatar
Brotherhood #1
36 is what mine was set at similar set up.
Sick Stinger is offline
Old 02-12-2010 | 01:55 PM
prolly, how do i move it?
302Sport is offline
Old 02-12-2010 | 02:04 PM
36...start a new one in tech
Back4More is offline
Old 02-12-2010 | 03:19 PM
start at 36 and go from there no more than 38....
antisocial is offline
Old 02-12-2010 | 04:12 PM
Panther's Avatar
Frank's Marine Service
what ignition are you running???
In general..... using an adjustable advance timing light, set it to 36*. Rev the engine to...3500pms while checking the timing... With the light set at 36* and the engine at 3500 you want to set the timing mark on the Balancer at TDC mark and "0" advance on the timing tab....
Panther is offline
