Miss in 525efi >
Miss in 525efi
Miss in 525efi
Old 02-16-2010 | 11:48 AM
Default Miss in 525efi
Ok, here goes. Last fall, getting ready for winter storage, I added stabilizer to my fuel and went out and ran the boat a couple of times to get it circulated. Just before pulling out of the water, the engine developed a miss. At idle you cant hear for feel it, but under load, it misses terribly. It cleans out once you get it up and on plane. Almost sounds like a plug wire(s) breaking down (engine has 260 hours). Just curious if stabilizer would foul the plugs or if it would cause the fuel filter to clog reducing flow. Doesn't make sense to me. It ran perfect all season, but didn't start this until i added stablizer. I am going to change the filter and water pump before season starts. Will probably pull the plugs and replace them as well. Any thoughts would be greatly appreciated.
Stogie is offline
Old 02-16-2010 | 12:26 PM
Fuel Stabilizer should not cause anything like that.
Griff is offline
Old 02-16-2010 | 04:30 PM
Default Fixx
was it cold out when you drove the boat?
FIXX is offline
Old 02-16-2010 | 09:28 PM
Air temp was high 60's, low 70's. Water temp was probably in the same ball park.
Stogie is offline
Old 02-16-2010 | 09:29 PM
My 525 EFI did something similar last summer. It would idle just fine, hesitate, backfire, miss, when applying thottle, and then clear itself out and run ok in mid to upper rpm range ... ended up being a MAP sensor going bad. No alarms, at first, but it kept getting worse throughout the day until it started giving an intermittent alarm code (can't remember the number of beeps in the sequence anymore) but the manual listed a variety of sensors that had that alarm code sequence. When they put it on diacom, it showed a bad MAP sensor. They installed a new one and it instantly ran fine again. Not saying that is your problem, but that is what my engine did, and that was the sensor that was bad. Several of "us" were betting it was a bad IAC. Have it scanned and see what codes are stored, if any.
bob_t is offline
Old 02-16-2010 | 10:31 PM
Wink Lets get out the Dart Board!
Hook it up to the scan tool under load and find the miss or stumble. Don't guess, you'll only be 50% right on a guess at best!
Best Regards,
Ray @ Raylar
Raylar is offline
