Bravo Outdrive Service Cost????? >
Old 02-16-2010 | 05:28 PM
Default Bravo Outdrive Service Cost?????
What should a good marina using mercury parts doing the full correct service charge for the labor portion of a Bravo outdrive winter service for twins?
ActiveFun is offline
Old 02-17-2010 | 01:58 AM
What kind of service are you talking??? Just a lube change and grease gimbal???? Probably about $200-250. If you are talking removing drives and checking alignment, then add another 2 hours of labor/$200 or so.
Griff is offline
Old 02-17-2010 | 08:38 AM
I dont have the parts list with me, full winter service, drives off boat, zincs, seals. Are those prices for both or each?
Old 02-17-2010 | 12:03 PM
That would be for both. Changing lube and greasing the gimbal is about $100 in lube(retail) and an hour labor. Add probably another $50 per drive for zincs.
What seals???????? There should not be any seals to replace unless there is a problem.
Griff is offline
