Fuel Supply for  GEN5 block, after market? >
Old 02-18-2010 | 09:37 AM
fastedy's Avatar
Default Fuel Supply for GEN5 block, after market?
I have a gen5 block and running an electric pump but I would like to get away from it, should I just get the Merc waterpump to run a mechanical pump or does anyone else make this type of set up, any part numbers would be helpful, 650hp Carb'ed
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
fastedy is offline
Old 02-18-2010 | 09:47 AM
Default fixx
i have a spare sea pump for a gen 5/6 with the fuel pump boss ,send me a email and ill send you pic's
[email protected]
FIXX is offline
Old 02-19-2010 | 06:43 AM
fastedy's Avatar
thanks, how much do you want for it?
[email protected]
Mario Andretti
fastedy is offline
Old 02-19-2010 | 11:31 PM
Just keep in mind that the water pump does not take a standard BBC fuel pump. The arm on the fuel pump that goes into the water pump is different than a BBC. You must use the correct pump. You can change the pump section to get more fuel flow, but you have to use the stock type upper housing. KE (Hardin Marine) makes a nice replacement pump section. Good luck.
Eddie
Young Performance is offline
Old 02-22-2010 | 03:46 PM
Keep the electric...that setup is B/S !! and very expensive to maintain..
ezstriper is offline
Old 02-22-2010 | 04:00 PM
Rookie's Avatar
+1
Rookie is offline
