500 EFI heads-freshen up or replace? >
Old 02-21-2010 | 07:32 AM
INDY27's Avatar
Default 500 EFI heads-freshen up or replace?
I have a pair of 2003 500 EFI's with 2.3 Whipples with about 180 hrs, heads are stock and have no problems yet but the valve springs are probably tired and all the recent ethanol/valve seal issues I am considering reworking or just replacing my heads with aftermarket and then selling the stock ones...any suggestions?
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 02-21-2010 | 11:25 AM
INdy27,
I just rebuilt mine, magnafluxed, guides, seals, resurfaced, 3 angle valve job @174hrs. We checked the springs and they were still at spec. Did this preventatively while upgrading to Cometics. I think I remember reading that the springs are good for 300 or so hrs. but don't quote me on that. Eddie at Young Performance will know the facts as well as a hand full of the other pros on OSO.
All that said, my engine has been nursed, but if I was reamin er out, would have replaced everything.
I was gonna put alum. heads on but the motor would have had to come out for tuning Eddie said, I did not wanna have to go to that extreme just 4 head gaskets. I the future when she's tired, I will step up to the next level.
Greenkeeper is offline
Old 02-21-2010 | 12:09 PM
offshoredrillin's Avatar
depends on what you want out of it. if you are happy with the performance just redo them the way they are, if you want more then you can go aftermarket. however like said above, once you do that, you have to address some other issues like comp and fuel, start putting in more air and not change the fuel map = boom.
offshoredrillin is offline
Old 02-22-2010 | 01:09 AM
Strip Poker 388's Avatar
Rob
also if he rebuilds ,replace the springs,cheap and not worth the chance!!
Im still stock heads.also is ya go beter flowing you will have to turn the blower harder,
Strip Poker 388 is offline
Old 02-22-2010 | 01:45 PM
INDY27's Avatar
Hey Rob,
You have Mark Boos number handy?
Thx,
Lee
INDY27 is offline
Old 02-22-2010 | 03:48 PM
Hey Rob,
Thx,
Lee
http://www.pmefi.com/
Old 02-22-2010 | 05:55 PM
INDY27's Avatar
Thanks offshore!
INDY27 is offline
Old 02-22-2010 | 10:25 PM
Rob
Rob your fast,what ya doing over here dude
Old 02-23-2010 | 09:15 AM
As Rob (Offshoredrillin) said, it all depends on what you want. If you are happy with the current power output, then just freshen them up. If you are looking for more, then go to aftermarket heads. Just keep in mind that if you go to alum. heads, then there will be some programming to be done. There are a few of us that can do it.
The weakest links in the stock setup are the exhaust valves and the head gaskets. Personally, with the time on them, I would rebuild the heads with new valves, springs, retainers, locks, seals and head gaskets. Use a good set of valves (like Manley), good springs, 10* retainers and locks (instead of the stock 7*) and a set of good head gaskets (Cometic, or similar) This is where you need to make a decision. At this point, the only additional money to go to aftermarket heads is the cost of the bare heads. You are already buying all the hardware anyway. If you decide to go to alum. heads later on, then all the money you spent on hardware for the stock heads is wasted because the alum. heads will take all different hardware. It will basically cost you about $1500 additional to go to alum. at that point. That is why I say you have to make the decision at this point.
Give me a shout if I can help in any way. Thanks
Eddie
Young Performance is offline
Old 02-23-2010 | 10:41 AM
winter, car bus is slow, doin paperwork..etc etc etc...
