wet stringers/bulkheads
Old 02-27-2010 | 11:28 AM
Angry wet stringers/bulkheads
hey guys my stringers and bulk heads are wet and heavy but not rotten
what shall i do
cheers gerard
gerard is offline
Old 02-27-2010 | 11:46 AM
glassdave's Avatar
Neno the mind boggler
damage is most likely already done. Even if you can dry it its not long before it comes apart. Once that water gets in there the swelling of the wood and (not sure if this applies) freezing/thawing can cause permanent damage at the cellular level and also the laminations.
what kind of boat?
08 OPA High Points Champion
glassdave is offline
Old 02-27-2010 | 12:01 PM
pantera 28
i was looking to keep the boat as light as possible
so i guess i get the saw out
what would you reccommend i use for new ones
cheers
gerard is offline
Old 02-27-2010 | 03:44 PM
rchevelle71's Avatar
Doing my 24 Pantera now, cant post pics here, but I got the transom out, notched the stringers, they seem OK, but may do the back few feet just to be safe.
rchevelle71 is offline
Old 02-27-2010 | 03:54 PM
i have removed the cabin floor it was heavy
i done a moisture test on the fromt stringers they seem ok
it just seems to be the two bulk heads each side of the tank the firewall is also dry and sound
the transom seems ok too
send me your email so we can exchange pics
cheers gerard
gerard is offline
Old 02-27-2010 | 03:56 PM
chuckbeecher
From: Anywhere from the Laguna Madre to JAX and beyond
Call Pepe!!!!!!!!!!!!!!!!!!!!!!!
get the experts opinion!!
chuckbeecher is offline
Old 02-27-2010 | 05:58 PM
Thumbs up
i will do ill call him monday an see what he thinks
guys thanks for the help
gerard is offline
Old 02-28-2010 | 09:16 AM
bigboat28's Avatar
What year is your boat?
bigboat28 is offline
Old 02-28-2010 | 03:07 PM
glassdave's Avatar
Originally Posted by gerard
pantera 28
cheers
if you are looking to lighten it up a bit use a Coosa Bluewater26 for stringers and bulkheads but you will have to modify how the engine mounts.
Old 02-28-2010 | 04:53 PM
as far as i know its 1989
gerard is offline
