Stuff that mounted to stock exhaust.... >
Old 03-05-2010 | 09:55 AM
Default Stuff that mounted to stock exhaust....
I replaced the stock cast iron exhaust on my boat with better stuff - however, the throttle and drive controls mounted to it.... I an guessing that there is a bracket I can get that bolts to the carb mount or intake or something.. Anyone know where I can get a couple of these? The ignition module that mounts on the other side was replaced by MSD box already, so no need for that mount. But there is still the oil filter which also mounted to the exhaust... Perhaps someone has the stock stuff (mounts or whatever) from a 496HO they took off?
Let me know!
Thanks!
Dustin
spunner is offline
Old 03-05-2010 | 12:08 PM
axapowell's Avatar
Where To
I have a couple of mounts from a Gil set up that might work. I'll try to post a couple of pictures for you.
Dave
axapowell is offline
Old 03-07-2010 | 11:13 PM
Just mount the shifter bracket and remote oil filter assembly on the transom. Use a 1.5" Angle Steel(paint it) or Aluminum to make a mount for the remote oil filter assembly.
Griff is offline
