Gen 6 454 Buildup - Alum Heads/Intake/Cam
Contemplating taking a Gen 6 merCruiser 7.4L Bravo 300HP short block, which is a stock 8.0:1 compression engine, and putting a set of Brodix "Big Brodie" aluminum heads and an Edelbrock Performer RPM aluminum intake, with a Holley 850 carb onto it. I'm also considering swapping the camshaft to a Comp 280AH-10. Basically sistering two engines together to make one.
Thoughts?
Harry
Thoughts?
Harry
it all depends on what brodix head your talking about!(they
ALL say "big brodie" under the v.c.! if their, BB-1's, BB-2's
or BB-2+, go for it!--if not, there probably too big (I'm assuming this is an I/O app.) as for COMP CAMS, I personally
don't like the stuff, don't run them, so I don't know the grind
your refering to.
your refering to.
