500efi backfired? >
500efi backfired?
500efi backfired?
Old 04-20-2002 | 12:50 PM
Strip Poker 388's Avatar
Rob
Default 500efi backfired?help needed
bought used boat, when running on hose ,cold natured, not much throtle responce, blip throtle off idle to about 1500 backfired up into intakewater temp was around 130-140,what do you think?
thanks rob
Strip Poker 388 is offline
Old 04-20-2002 | 05:54 PM
mcollinstn's Avatar
possibly injectors need cleaned.
possibly timing needs set.
possibly needs plug wires.
Most likely just needs a new water separator filter and a tank of fresh gas run thru it.
M
mcollinstn is offline
Old 04-20-2002 | 07:40 PM
hopefully it's not a worn cam lobe due to a stuck exhaust valve like i just had.
excaleagle42 is offline
Old 04-22-2002 | 03:59 PM
Rob
it ran fine friday but sat poping up in intake , down on power, want rev past 3800,other motor is ok,they washed the engine compartment may have water in something,any sugestions anybody????????
Old 04-22-2002 | 04:16 PM
birdog's Avatar
Theres youre answer Rob!! Water in the electroics!!!! Try WD40 on all connections & around wires ....Should fix ya right up!!!
birdog is offline
Old 04-22-2002 | 08:07 PM
blue thunder's Avatar
Birddog is right. Just remove distributor cap and spray some water displacing stuff and you will be good to go.
BT
blue thunder is offline
Old 04-23-2002 | 02:53 PM
Rob
cked the dist was dry,ck all conections ecept the ecu willtry next,the swap the ucu with other motor, ran merc scan tool no codes,replacing plugs ,caps ,rotors ,water seperators tonite see what happens,it was poping trying to get on plane just on one motor,other was fine,motors have 50 hours,has fresh gas with heet and fuel injector cleaner in it,new boat blues?
Old 04-24-2002 | 09:08 AM
turbo2256
Do a compression check before you replace all that stuff if you havent already
ar15meister
02-28-2008 06:56 PM
stsrick
Prop Talk
4
06-19-2006 06:23 PM
offthefront
75
01-11-2005 07:47 PM
Donzi26ZX
05-30-2002 09:17 PM
