Ignition Wire opinions >
Old 03-12-2010 | 09:56 AM
Prater's Avatar
Default Ignition Wire opinions
As I was inspecting my engines, I noticed the MSD plug wires are cracked. Just curious what plug wires you would recomend with the 177 supercharged engines running T-Bolt ignition with blaster coils and MSD rev control. I will probably change the plugs also if anyone has some recomendations.
Prater is offline
Old 03-12-2010 | 10:23 AM
Throttle Fever's Avatar
Moroso Ultra 40's. The best of the best. NGK plugs.
Throttle Fever is offline
Old 03-12-2010 | 11:04 AM
I like the factory mercruiser blue wires. Hold up well. No cracking. had same problem with MSD. NGK plugs.
steveh1209 is offline
Old 03-12-2010 | 11:26 AM
NGK UR5 sparkplugs. They are the equivalent of an AC R41TS.
Griff is offline
