Lubricant for TRS Lowers >
Old 04-21-2002 | 02:03 AM
magnuman's Avatar
Question Lubricant for TRS Lowers
What is th best lubricant for TRS lower Unit?
Also fluids for Trannies?
Thanks.
magnuman is offline
Old 04-21-2002 | 02:50 AM
Audiofn's Avatar
Charter Member #232
I use Merc High performance gear lube in mine.
For the Transmisions I use B&M Trick shift. So far they seem to shift much nicer with the Trick shift in them then regular ATF. You can mix the Trick shift at any percentage you want to with ATF, or use it full strength. I use it full strength.
Jon
Put your best foot forward!
Audiofn is offline
Old 04-21-2002 | 01:27 PM
magnuman's Avatar
What is the weight of the Mercury Hi-perf oil?
I have used RedLine 75-90W Limited Slip Differential oil before.
magnuman is offline
Holy Smokes
9
09-19-2006 10:55 PM
Harper220
9
09-21-2004 05:25 AM
Darkhorse468
Sutphen
5
06-26-2003 11:28 PM
Darkhorse468
2
06-20-2003 06:08 PM
magnuman
2
04-21-2002 09:48 PM
