edge juice with attitude LB7
Old 03-15-2010 | 08:46 AM
Default edge juice with attitude LB7
i have a edge juice with attitude for an LB-7 2001-early2004 duramax diesel
sold the truck still have the unit. with box instructions and egt probe. egt probe was not used. everything is in great shape.
tony stamis is offline
Old 03-15-2010 | 09:22 AM
LapseofReason's Avatar
How much I got a friend that might want it.
LapseofReason is offline
Old 03-15-2010 | 09:45 AM
If you programmed your truck with the programmer and did'nt return it to stock before you sold it, it will be no good to anyone. These programmers vin lock the programmer to that vehicle. It can't be used on another until it is reflashed back to stock.
bobsbillets is offline
Old 03-15-2010 | 11:35 AM
That doesn't apply to this unit. This one doesn't actually reprogram the ecm. It's just a module that plugs into the truck's wiring harness and adjusts the signals being sent, etc.
Busta is offline
Old 03-15-2010 | 02:53 PM
Was unaware of that. Good info!!
Old 03-15-2010 | 08:49 PM
this unit is is adjustable on the fly when you disconnect everything the truck goes back to stock it was around $800 when i bought it if i could get close to $400 would be nice i will post pics of everything tomorrow. it does make incredible power when you crank it up and i believe you can get a sixth power level if you get the unlock code from edge.
Old 03-15-2010 | 11:20 PM
jonyb's Avatar
Great pieces indeed, but cranking it up is scary for the Allison.....
jonyb is offline
Old 03-16-2010 | 06:35 AM
never cranked it up 5 settings settings more than enough
Old 03-16-2010 | 11:23 AM
29KILROY's Avatar
scarey on all modes if you do not set it to Defuel during shifts..... I had one on my LLM (05') and loved it!!!
29KILROY is offline
Old 03-16-2010 | 12:55 PM
jonyb's Avatar
Had one on my LBZ and loved it....
jonyb is offline
