Wanted : Bravo 1 Lower case w/LWP >
Old 03-18-2010 | 09:52 PM
formula377's Avatar
Default Wanted : Bravo 1 Lower case w/LWP
I need a Bravo 1 Lower case with the Low Water Pickup Only.
formula377 is offline
Old 03-19-2010 | 09:33 PM
I have a lwp case what are looking to spend
cocktails is offline
Old 03-20-2010 | 07:53 AM
axapowell's Avatar
Where To
I have one also.
Let me know if it doesn't work out with cocktails.
Dave
axapowell is offline
Old 03-20-2010 | 12:06 PM
sac
I've got five of those!
sac is offline
Old 03-20-2010 | 06:25 PM
formula377's Avatar
Looking to spend about $300-$400.
I need a B1 lower case with LWP only. It can't have pickups on the sides or anywhere else!
Obviously I need one that is in good working order with no concerns.
Let me know
Old 03-20-2010 | 06:48 PM
axapowell's Avatar
Where To
I can hook you up in that range. Just the case right?
PM me your number.
Dave
Old 03-20-2010 | 10:47 PM
I Axa can help you with the case that's ok with me. Let me know if that doesn't work out.
Old 03-21-2010 | 09:58 AM
Ok, dumb question. I was an outboard guy before now, and I had a LWP with a bobs nose cone on it, and it has the hoses on the outside of the case..do bravo lowers with cones have the same set up? If so I might take one, ill just take the internals out of my case and put them in the lwp case..I have the small bravo case though..and hell I live in stlouis too..so we could go halfs on shippin...
stlliberator is offline
Old 03-21-2010 | 11:18 AM
formula377's Avatar
The LWP (Low water picpup) cases that I am refering to and looking for have water inlet holes in the nose cone only. Lower cases with LWP only do not have water inlet holes anywhere else, only in the nose cone. These are the ones I need to find.
Old 03-21-2010 | 02:36 PM
axapowell's Avatar
Where To
Thanks cocktails! Didn't want to undercut or step on any toes!
Dave
