Gill exhausts with closed cooling?
Hi folks!
Anyone have a picture or diagram of how Gill exhausts are configured with closed cooling on a Merc 454 or 502 carbed engine?
A picture would be ideal.
Thanks!
Thanks!
Russ
I put on closed cooling on my 500 hps with aluminum heads. Mounted the heat exchangers outboard each motor on the stringers. Put on a swivel tstat neck from Summit and routed the hoses to and from the exchanger on the outside of the tubes for the motor coolant.
Routed the raw water to the tube side of the exchanger. coming out of the exchanger I ran a hose to the tstat and clamped it on a "custom" made bracket with a tee. The hooked up the Gils hoses to the tee.
Runs great.
Runs great.
Long time cult member.
Thunderstruck - can you post or email me some pictures of your layout?
I understand where the raw and coolant wanter need to go but am not sure how to get the coolant water into and OUT of the Gil manifold. The raw water directly into the riser is pretty obvious.
Is there an "out" port on the Gil exhausts other than up through the riser? Do I need a block off gasket between the manifold and the riser?
Just plumb the sea water out of the exchanger into the bottom of the gils just as if you don't have closed cooling. Keep the rest of the plumbing for the gils the same.
Reread your post about coolant water into the manifolds. I have sea water on the manifolds and the risers/tailpipes. You may have too much heat load to put the manifolds on closed cooling along with the block. Also, you will need to balance the flow somehow evenly between the manifolds.
