Which thermo for a gen 5 502 mag mpi >
Old 03-25-2010 | 05:36 PM
Default Which thermo for a gen 5 502 mag mpi
Im in need of a new thermostat for my gen 5 502. There is a couple of options, a 140, or a 160 degree..
stlliberator is offline
Old 03-25-2010 | 06:03 PM
Throttle Fever's Avatar
Closed or open cooling system? Water pump or bypass?
Throttle Fever is offline
Old 03-25-2010 | 06:05 PM
You need the 160 degree to keep your stock EFI engine from running to rich and fouling out the spark plugs.
Boat Tech is offline
Old 03-25-2010 | 08:52 PM
All the Merc black EFI engines use a 160* TStat.
Griff is offline
Old 03-26-2010 | 06:32 AM
ballon78's Avatar
160 just removed mine last month. Make sure you get a new cork gasket up top too, they turn into a bock of rust, cant even tell there one in there!!
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
