Thunderbolt IV module on Thunderbolt V ? >
Old 03-26-2010 | 06:35 AM
ballon78's Avatar
Default Thunderbolt IV module on Thunderbolt V ?
just did a 454 to 502 swap and have TB V ignition with knock sensor. My rev limiter is too low at 4700-4800 so i want to change it. Can i just unplug the TB V ignition module and plug in the TB IV one? Will the TB IV work with the knock sensor or do i disable that too by unpluging it too?
What is the best Ignition module for my New gen 6 502 415hp carb holley 800, EMI headers with long tubes? IN a heavy baja outlaw24.
Dont want to go MSD, want to keep the super reliable TB ignition!
thanks
96 HUSTLER 32, Vacuumed bagged layup, composite transom Blueprinted 502EFI's Mayfair, Dry-exhaust
ballon78 is offline
Old 03-26-2010 | 09:15 AM
Some else might speak up but isn't a TB V controlled by the ECM and knock sensor. TB IV does not have an ECM.
1BIGJIM is offline
Old 03-26-2010 | 09:18 AM
ballon78's Avatar
Mine doesnot have a ecm just a Ignition module and the a knock module on top...let me see if i can get a pic..I know that some do have an ECM but i think only on TB V that ate v6 4.3. Mine was a 454 carb 330
ballon78 is offline
Old 03-26-2010 | 09:24 AM
ballon78's Avatar
THis what I have....very simular to the TB IV...no ecm..
CHECK OUT PAGE 16, AND THEN THE WIRING CHART.
http://www.boatfix.com/merc/Servmanl/16/16B4R2.PDF
ballon78 is offline
Old 03-26-2010 | 11:56 AM
You could just get a TB IV module and the plug in harness that goes with it. It will not have any rev limiter. That or get a TB V module from a different, higher reving engine. PM rsteiny, he may have a V off his. You could probably also have the rev limiter raised in your module, but not sure about that.
Griff is offline
Old 03-26-2010 | 01:55 PM
ballon78's Avatar
Griff, did u see what the module that i have looks like? It sort of looks like a TB IV module but its a TB V. its nothing like the HP500 or bulldog 500 TB V module, those look more like an ECM and have two conections on them. I know my module that i have isn't progrmable, the color on the wiring schematic are the same except for the wire that goes to the knock sensor. i just dont want to get into switching my entire harness over, cuz i just got done, extending some things and retapping and wire looming the whole thing before i droped my new motor in last weekend.
Do you think mt stock 502 mag shold rev more than 4700? i think thats where my rev limiter is set at but dont know.
ballon78 is offline
Old 03-26-2010 | 05:26 PM
All the info you need can be found at the link below assuming you are talking a 502HO (450HP)
Max RPM = 5500
Max HP is made at about 5200
http://www.gmperformanceparts.com/En...8778&engCat=bb
502ss is offline
Old 03-26-2010 | 05:53 PM
Yes, I saw the pic. Yours is on page 4B-14 right??? Your module is the same as what was used on TB V carbed 500hp's. Yours is just mounted on the distributor and the 500HP ones were not.
http://www.mercruiserparts.com/Show_...RU+0L001772%29
Griff is offline
Old 03-26-2010 | 07:36 PM
ballon78's Avatar
Ya thats mine, I think i figuared out what to do, i just need to get a 454 Mag module from a thunderbolt V!!! Dont know whay i didnt think of that way back......I however gooled the part number and cant find one unless i buy new and they are 400 plus dollors. Someone i'm hoping has one. I think the mag has the rev limiter at 5250.
806745A01 MODULE-Ignition Control old number 806745T5 (454 MAGNUM)
ballon78 is offline
Old 03-27-2010 | 01:56 AM
454mag will have a 5150 rev limit and the 500HP will have a 5350rpms limit. Either will work fine.
Griff is offline
