Little white plastic engine cover drains
Anyone know where I can find the little white plastic drains that are used on the underside of the engine compartment cover to allow water from the foam to drain? Boat is a 1996 Boss 302.
Thank you!
Thank you!
I just bought a dozen of them off of sport boats marine in fort myers fla. Im sure most marine dealers should have them.
Get ahold of Dave xt innovator, he sould have them also.
If you can't find them, you can go to Lowe's and get the 1" plastic plug covers in hardware. They are the exact same thing, other than you have to use one of your existing plugs and drill the holes in them.
Do they turn yellow for everyone else? The ones on our '05 275 yellowed within 2 years and the ones on the '08 (not even in service a year) are beginning to yellow. I'll just spray paint them w/ white plastic paint again - but annoying. Also, they don't like to stay in from factory but I always silicon them in.
Just ordered 6 from Ted at Sport Boats Marine in FL. Nice guy and knowledgeable. Knew exactly what I was talking about and has a few dozen left that he kept in stock from when Baja was around.....If you need some, Ted's got them. Thanks.
Put some glue on them or they will fall back out.
