3 Blade vs 4 >
3 Blade vs 4
3 Blade vs 4
Old 04-22-2002 | 02:37 PM
HENRY SHARP
Default 3 Blade vs 4
I have a 3 blade mirage plus 23 running 5000 rpm @68mph would a 4 blade increase my top end or hurt , trying to get to 70mph. I have a baja 25 outlaw w/ 496HO
Old 04-22-2002 | 02:39 PM
obnoxus's Avatar
Charter Member #1171
My guess is it would help your hole shot and hurt top end,,, I tried it on my 272 and it hated it,,, no bow lift,,,, and her butt walked all over the place.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-22-2002 | 03:35 PM
Mbam's Avatar
Offshoreonly Advertiser
Try a Mercury Revolution. Has added a few MPH on some hulls.
Mbam is offline
Old 04-22-2002 | 07:16 PM
HENRY SHARP
Default rev 4
Marc what is your experence with the outlaw 25 hull and the 496HO
Old 04-22-2002 | 07:27 PM
bajadude's Avatar
Henry,
I had a 2001 Outlaw with a 454 MPI turing a 23P Mirage. With gear, 2 people and 1/2 tank, I was able to get around 69 on GPS. I would think with the extra HP of the 496 HO you should be clipping 70.
Anyway, I'd go for a 24P B1 or maybe a 25 Mirage.
bajadude is offline
Old 04-22-2002 | 08:05 PM
Mbam's Avatar
Henry, I have no personal experience with that set up. I can tell you that the Rev 4 will pull 300 RPM less than the same pitch in a Mirage. In a couple of the magazine tests, the Rev was almost as fast as a labbed Bravo 1. In my experience the Bravo 1 prop has too much blade area for a boat that size. The Rev seems to be faster. Sonicdude might be right on the money with the 25 Mirage, it will drop you 400 RPM or so, but probably pick up a mile or two. My bet would be the 23 Rev or the 25 Mirage. then lab finish the one that you like. Bottom line is you need to experiment.
Mbam is offline
Old 04-22-2002 | 08:25 PM
26scarab's Avatar
Mbam.
What is the difference between the Rev and the B1 ? Does one had more bow lift than the other ?
I currently run a labbed B1 and am happy with it but if a couple of mph is to be gained I'm all ears !
26scarab is offline
Old 04-22-2002 | 08:49 PM
Tinkerer's Avatar
Cool
Why not just lab the prop you have. You will be over 70 mph.
Tinkerer is offline
Old 04-23-2002 | 02:15 AM
I tried a 23" Rev 4 on my 24 Outlaw. WAY TOO MUCH stern lift. More trim did not help and couldn't get enough bow lift. Slowed the boat down 4mph. Get a 25 Mirage plus. Run it stock and see where the rpms are at for a base line, then send it to get labbed. Labbing your 23 is probably not an option unless you have them change the pitch also as you're 100-150 rpms away from the rev limiter.
Griff is offline
Old 04-23-2002 | 02:17 AM
Also, if you have any mufflers changing to straight tips may give you a 100rpms.
Griff is offline
