Increase HP on Merc. 6.2 MPI >
Old 03-31-2010 | 03:58 PM
Default Increase HP on Merc. 6.2 MPI
I'm looking to increase the HP on my twin 2005 Merc. 6.2 MPI. The engines put out 320 HP at the prop now, I'd like to get the HP up to 375 to 400 HP the most economical and reliable way possible. Any recommendations for an easy fix, is there a chip that increases HP, etc.? Thanks.
36Envision is offline
Old 03-31-2010 | 07:32 PM
6.2 your best bet is to pull them out and replace with big blocks, 6.2's are pretty maxed at 320hp.
TampaBeach is offline
Old 03-31-2010 | 11:14 PM
Get a new engine.
redbud35 is offline
Old 04-01-2010 | 01:37 AM
Originally Posted by redbud35
Get a new engine.
Agreed. Going from 320hp perside to 400hp is only good for about 4-5mph.
Griff is offline
Old 04-01-2010 | 06:18 AM
Indy's Avatar
Member #154
Get a new engine.
Bingo...don't waste your money or time.
Indy is offline
Old 04-01-2010 | 08:54 AM
trade it in on something with blue motors
GL@PBC is offline
Old 04-01-2010 | 09:33 AM
You would need to replace the intake manifold to get any power increase. The stock intake just doesn't flow enough air to support any HP increase. With a a carb or aftermarket efi, cam change and some head work you can get 400 HP. Beyond that, change engines or leave it alone.
bobl is offline
Old 04-01-2010 | 10:04 AM
whipple charger mite work
mikebrls is offline
Old 04-01-2010 | 10:29 AM
Those were my initial thoughts too, I'll probably keep the boat for another season then look for something new in the winter months. Thanks for the responses.
Old 04-01-2010 | 11:13 AM
Indy's Avatar
Member #154
I remember Uncle Toys tribulations with those on his 6.2...what a saga that was.
Indy is offline
