What do you tow with an 08 or newer Ford Expedition? >
Old 04-01-2010 | 03:46 PM
Default What do you tow with an 08 or newer Ford Expedition?
I have a 1987 35' Cafe Racer. I believe that the weight is between 9,000 - 10,000 lbs. +/-, not including the weight of the trailer. According to the tow guide, a 2WD 2007 Expedition has a 9,100 lb. tow rating. If I was looking at the tow guide correctly, it appears that a 2WD 2500 Chevy and the F-250 have tow capacities in the same ball park of the Expedition.
Really, all I need to do is get the boat home. Well, at the dry storage facility anyway. It's roughly a 60 mile trip.
ajacobazzi is offline
Old 04-01-2010 | 04:31 PM
Default Fixx
Can it pull it? yes, my concern would be stopping and the weight rating on the hitch..also check your local dmv on your plate restrictions..a regular car plate is only good for xxx amount of weight and the local officer will give you a ticket for over weight..here in chicago i think the weight on a regular plate is 8000 pounds..also if your not using a weight distribution hitch you may be over on the hitch rating and believe me they will bend and brake..
FIXX is offline
Old 04-01-2010 | 04:40 PM
Thank you for the reply. I'm originally from Chicago......I miss it there. I live in Florida, but, Chicago is home. Go to Portillo's for me tonight! LOL!!
We don't have different plates here like Chicago does. Let's see, if I remember correctly, pick-up trucks have "B" plates, right? And stay off Lake Shore Drive and Blvds. too?
I have a factory towing package, so I'd imagine that the hitch is rated for the tow rating of the vehicle, would that be a safe assumption?
As far as the braking issue, wouldn't the trailer brakes make up for any loss from the vehicle?
Old 04-01-2010 | 07:19 PM
That is not a safe assumption on the Receiver.... I have an 08 ram 3500 and it's tow rating is GCWR of 24,000 and a rating of 13,900lbs on the tag along and it came with a 10,000 lb hitch. Same crappy hitch as my 2005 had on it. I put a 18,000 class V titan with a 2 1/2" receiver on and feel much more comfortable my load is going to stay connected.
baywatch is offline
Old 04-01-2010 | 07:33 PM
t500hps's Avatar
21 and 42 footers
I've seen a number of F350's with 5,000lbs rated hitches on dealer lots....why, I have no idea. Just don't assume yours is enough. An aluminum trailer will be around 2,000 lbs, a steel will be over 3,000 easy...plus fuel and gear. Considering those old Cafe's were heavy boats (probably more than you listed) I bet you'll be pulling around 14-15,000. If you do it, stay OFF the highway and go slow enough that people are flipping you off as they pass.
t500hps is offline
Old 04-01-2010 | 07:55 PM
seafordguy's Avatar
I am not one of those guys who blow things out of proportion or get all jazzed up over Tow Capacities but WOWZER - I tow my Cafe with an F350 diesel Dually, and I can promise you it is the smallest truck I will EVER own. That cafe is 10k plus fuel, plus the trailer, plus the gear. I assume that I consistently run around in the 14k range.
That Expedition will have a hard time controlling that boat - REALLY!!!
It will have a hard time getting it going and it will have a real hard time stopping it. I would be careful, or see if there is someone on here with the right truck who would yank it for you.
seafordguy is offline
Old 04-01-2010 | 08:27 PM
Thank you everyone for the insight. I suppose, the easiest, safest and smartest thing to do is to have the dealer deliver the boat to the marina for me.
Old 04-01-2010 | 10:29 PM
A good decision. Anything can happen in 60 miles and you do NOT want to be in an accident overloaded.
Catmando is offline
Old 04-01-2010 | 11:09 PM
A expedition does not have enough suspension, wheelbase, brakes, or powertrain to do this.
MILD THUNDER is offline
Old 04-01-2010 | 11:14 PM
PhantomChaos's Avatar
I used to tow a Formula 312 with a Lincoln Navigator......similar truck to the Expedition. It had that auto leveling airbag suspension which was cool. I upgraded the factory hitch to a 15K hitch, but really......it was not a good thing. I had surge brakes....not too fun. Wasn't probably legal and if something would have happened.....probably wouldn't have been covered.
These pics will give you an idea.
Attached Thumbnails What do you tow with an 08 or newer Ford Expedition?-p0001120.jpg   What do you tow with an 08 or newer Ford Expedition?-p0000397-w.jpg
PhantomChaos is offline
