lower bolts in a bravo 1 transome >
Old 04-01-2010 | 08:17 PM
Default lower bolts in a bravo 1 transome
I am wondering if the 2 lower bolts in the transome are susposed to be aluminum? That is what I found anyway and they are completely eroded away. I want to replace them with stainless bolts any input?
ken3765 is offline
Old 04-04-2010 | 07:23 PM
Stainless would be best i would say especially in salt water
firehawkcat is offline
Old 04-05-2010 | 09:07 PM
PAST DUE's Avatar
i'm sure if stainless was the best to use in that area mercruiser would have put them in there.
PAST DUE is offline
Old 04-05-2010 | 10:32 PM
yes past due I would have to agree. But I have yet found a replacement online. I have found zinc but not aluminum
ken3765 is offline
Old 04-06-2010 | 06:22 PM
PAST DUE's Avatar
they may have changed the material that they are made of will check tomorrow.
PAST DUE is offline
Old 04-06-2010 | 10:26 PM
replace with stainless,no reason to use aluminum.
mike tkach is offline
Old 04-08-2010 | 08:47 PM
I installed the stainless. This boat will not be sitting in salt water for long periods of time. I wanted the strength and longegivity. I let you know if i find out different.
ken3765 is offline
Old 04-14-2010 | 08:43 PM
PAST DUE's Avatar
you are setting the transom assy up for some bad corrosion in the area of the ss bolts, some corrosion you may not be able to see. all the bolts that hold the transom plate assy are on the inside of the boat so salt or freash water cant get to them. the two bottom bolts that are exposed to the water are made of alum and have anodes on the end of them for a reason........ corrosion. would you rather have to replace two lower bolts every so often or a transom plate assy??
PAST DUE is offline
